disable auto-provision
Description
Disables the auto provision capability.
Syntax Description
Default
N/A.
Usage Guidelines
Use this command to disable the auto provision capability.
To display the status of auto provision on the switch, use the show auto-provision command.
The following command disables the auto provision capability:
The following message is displayed:
# disable auto-provision
This setting will take effect at the next reboot of this switch.
This command was first available in ExtremeXOS 12.5.
Platform Availability
